Reset for Autoride System?
Just replaced front left ride height sensor in a 2002 2500 Suburban LT. The "Service Auto Ride" message is still on. Is there some type of reset necessary?
Repair was done after a dealer told me on a roadtrip over the summer that this sensor was bad. They did not have the part so I waited.
It is nice that you got through the ride height sensor repair. If you have a code reader, you may want to scan the truck and note the code(s) that are listed. If you do not have a code reader, maybe you can find someone with one. In some cases the codes will reset after a few start cycles and in other cases, you need to clear the code.
If you do get a list of codes, you can post them here and someone will be able to help you with additional steps.
nbmech
August 24th, 2012 7:22 AM
