Reset emergency brake
RE: Reset emergency brake
I'm not sure what you mean by "reset the mergency brake"? Is the brake too loose or too tight? There is usually an adjuster in the cable to take up/loosen up the brake. What's the symptoms?
ORIGINAL: n1wvet
Chaz called Auto Aone and they said it shows the diagram so I hope to go there today and get it so he can see what to do. Chilton books are so lame. We found a book for mechanics they use at the garage. $141.00 at www.helminc.com... He wants one for all our vehicles Yoweee!!! He has a 2005 SSR you never know when it will need it.
Thanks again
2003 Tahoe owner,
Diney
The park brake adjustment is made back at the rear disc/drum, there is an adjuster nut that needs to be turned until the park brake shoes just barely make contact with the drum.
I should add also that once the shoes are adjusted you need to adjust the park brake pedal by setting the park brake pedal and releasing it at least 3 times.
bkordrs
May 15th, 2011 12:05 PM
melat70
August 25th, 2007 11:01 PM
