Reverse Camera Questions
Old Mar 10, 2007 | 5:14 AM
scott_mckinney's Avatar
Default Reverse Camera Questions
Hi. I have a 2007 Chevy Tahoe LTZ. The vehicle had the factory Bose Navigation and all the goodies, incluidng the factory reverse camera... I have installed a new ValorDVD receiver. The receiver simply needs a ground wire to know when it is in reverse and the RCA camera feed. I would like to use the factory reverse camera to do this. I read some of the posts online, but none really directly answer my questions and confused me quite a bit. What exactly do I need to do?Can anyone help me out?Please advise.
http://www.valordvd.com/FileForDownl...llingGuide.pdf
Old Mar 10, 2007 | 5:45 AM
gm_geek's Avatar
Default RE: Reverse Camera Questions
reverse trigger can't be ground. it's always positive. check link below, it has some pics where You can get that trigger from
http://www.cadillacintegration.com/2...o_Install.html
now, check brown connector that used to be attached to your factory nav radio
pin#6 Pink is camera posive
pin#7 light blue is camera negative
You can solder them to male RCA connector and that's it. or splice them to a piece of RCA cable with male on the other end
Old Mar 10, 2007 | 5:49 AM
Hi. Thanks for the info, where is that location they are referring to, the BCM module? So I can connect the dark blue wire down there to my wire on my unit for the proper ground I need? No wires I can use for this behind the dash in a simple location?
http://www.valordvd.com/FileForDownload/InstallingGuide/NVG-670WTInstallingGuide.pdf
Old Mar 11, 2007 | 1:35 AM
Hey Guys. Well I hooked up the camera how you explained, using the RCA end and the pink as positive, light blue as negative, does not work. What else can I try or check?
Old Mar 13, 2007 | 3:32 AM
Nobody can offer any help? I cannot figure out the issue with the camera... I followed those directions to the proper wires.
Old Mar 13, 2007 | 5:00 AM
kernal's Avatar
Scott, not to deter from your post, but why does it take a lifetime for the screen to display????????? by the time it post up I'm already putting it in drive?? anyone knows how to speed up the process????
Old Mar 13, 2007 | 5:26 AM
Hi. What are you referring to? I have no idea what you are talking about...
Old Mar 13, 2007 | 11:15 AM
07LTZGREYSTONE's Avatar
THE REVERSE MONITOR
Old Mar 13, 2007 | 12:28 PM
Hi. You want to know what takes so long for the reverse monitor to display on my Valor unit? It doesnt if you ask me, its instant, but then again I do not have a working camera feed. Do you have the same unit or something?
Can anyone help me with my camera issue? How do I manage to use the factory OEM reverse camera with my unit?
Old Mar 13, 2007 | 1:04 PM
gm_geek's Avatar
ORIGINAL: scott_mckinney
fewthings could happened
may be on your aftermarket unit you need to turn your camera option ON. you can test it with a different camera, just to make sure that function is working on your Valore unit., or, since you disconnected your factory Nav radio, system lost communication with camera module (underneath passenger seat), in that case, you may need to bypass that module
