Right Turn Signal Help????
Right turn signal is flashing quickly, and, neither the front turn signal light nor the mirror light is flashing. Replaced front right bulb, no help. Checked wiring on mirror system, no help! Checked rear bulb and it works properly. Any ideas???
Thanks much!!!
Thanks much!!!
Welcome to the forum,
As you may have guessed the quick flash is a sign that one of the bulbs is out or the system thinks a bulb is out... since you replaced the front bulb and it changed nothing, I would explore the socket and wiring for the front bulb.
Raz75reb
September 19th, 2010 11:28 AM
