rough shifting
Old Mar 29, 2016 | 6:51 AM
jimbo409's Avatar
Default rough shifting
I have a 2001 with 154000 miles lately when my suburban shifts from 1st gear to 2nd when I start out it makes a thump sound.This also happens when I get off the highway and it slows down it seems like it makes a rough shift again.Someone said this could probably be a universal joint,any ideas.The transmission seems to work fine no slipping in any gears that I can feel.Just this thump from 1st gear once I get started it is smooth.Thanks Jimbo
Old Mar 29, 2016 | 8:49 AM
When my son's 2004 Tahoe started doing that, he had to get the transmission rebuilt. Fortunately we had had the BG transmission service performed and that comes with a warranty which paid for most of the rebuild.
Old Mar 29, 2016 | 9:00 AM
At 154k miles I would suggest at least replacing both u-joints as a preventative, and then see if shifting improves, also consider having the slip yoke lubricated to make sure it's not the splines binding because they are dry.
Old Mar 29, 2016 | 7:38 PM
cleveland63b's Avatar
definitely check ujoints and slip yoke but have you checked the fluid yet?
Old Mar 31, 2016 | 6:59 AM
extremeadventurer's Avatar
Check the transmission fluid level first.
