Rpm towing with my suburban?
Old Jun 2, 2017 | 8:34 PM
BOLSON SPORTS's Avatar
Default Rpm towing with my suburban?
I have a 2013 suburban with the 5.3 L V8. I recently bought a 26 foot travel trailer that weighs 5800 pounds dry . Suburban says towing capacity is 8000 pounds. With the trailer loaded I am probably in the mid 7000 pounds. What is a safe rpm range towing down the freeway? It likes to be at 2500 RPMs when I'm iaround 65 mph. Is it OK to get the RPMs up in the mid-3000 range when going up a grade for 5 to 10 minutes?
Old Jun 2, 2017 | 9:24 PM
yep, the engine can rev there all day. when towing, the stress will be on the trans...its severe service so service the vehicle under the severe service schedule.
Old Jun 3, 2017 | 5:46 AM
intheburbs's Avatar
I towed a lot all over the country with my '01 Burb. I towed in third because it was a 1:1 ratio and put the least stress on the transmission. With the 4.10 axles, this meant the engine was at 3200-3300 RPM at highway speeds. I towed THOUSANDS of miles like that. My buddy now owns the truck. It's at 240k with the original engine and transmission.
Easy way to figure this out - look at the engine's peak horsepower and torque numbers. The 5.3 makes max torque at 4000 RPM. It's happy there.
Old Jun 7, 2017 | 8:53 PM
falconbrother's Avatar
I tow a similar weight travel trailer with my 2000 Burb. The speed rating on the 2017 camper is 60mph. I have pulled it at 65 but, I never go over that. A blow out could be really bad. With Tow/Haul the RPMs are at 2500 on the interstate. It's perfectly healthy and doesn't hurt a thing. On hills I let the speed bleed off some because I want to keep my transmission healthy. I had to stop on a mountain last week because the LEOs had traffic stopped for a broken down semi. I started from a dead stop on about a 7.5 degree incline. In tow/haul the RPMs went way up before it shifted out of first gear, like 5000RPMs. I was pulling strong and seemed to be comfortable with that so I didn't fret over it. The 5.3/4.8 likes RPMs when under load. In tow/haul the overdrive should be locked out. Torque Converter lockup happens quicker and causes the transmission (fluid) to run cooler. Don't tow with the tow/haul off because the burb will engage overdrive on the highway and that overdrive was never intended to deal with that much torque. Also, the transmission will be shifting around a lot more. And, torque converter lockup wont happen as quickly meaning that the fluid will get really hot trying to pull that much weight. My next tow vehicle will be a 2500 Suburban or a Ford Excursion.
