Rusted brake lines.
Old Sep 22, 2017 | 1:31 PM
  #11
Raymond 1960's Avatar
Originally Posted by Matt B
I think I'll wind up doing a doorman kit myself. About 3 coats of some high-performance enamel- probably buy me 10 years of braking.
The Dorman kit is stainless steel and should not rust ,therefore it shouldn't require any coating.
Old Sep 23, 2017 | 7:43 AM
  #12
rubberized rocker guard is the best thing to coat the brake lines with....it resists stone chilps
Old Nov 22, 2017 | 1:30 PM
  #13
I felt obligated to report about my experience since I received so much help here.I chose to install the Dorman preformed kit.I found it on Amazon for about $85.00.With the help of my good neighbor it took us about 8 hours and didn't present any major obstacles.Since we couldn't view some of the lines,riding on top of the frame rails, we had to do it by feel in order to release the lines from the clips.It was a little slow going but we finished it and they're working perfectly.
Thank you forum members.
Old Nov 22, 2017 | 7:06 PM
  #14
you saved some money then. a shop would charge approx 7.5 hours labour to replace all 7 lines.
Old Nov 22, 2017 | 8:33 PM
  #15
oilcanhenry's Avatar
Thats about $700 dollars worth of labor, according to my math, around here anyhow.
Old Apr 15, 2018 | 6:03 PM
  #16
mmb617's Avatar
Hey Raymond 1960, glad to hear you didn't run into any major obstacles as I'm about to do this job myself. I had a line burst on my '03 Yukon Denali and when I put it up on the lift it was obvious that all the brake lines should be replaced. I went with the NiCopp kit from Rock Auto after looking at all the options. Hopefully I made the right choice.
My timing must have been good as I paid $104.79 when I ordered a couple days ago but I see the same kit at RA is now listed for $140.79.
The scary thing is my fuel lines don't look much better than the brake lines so they will probably get done next.
I'll let you know how it went in a week or two. I'm sure it will help a lot that I have a lift in my garage.
Old Apr 15, 2018 | 9:59 PM
  #17
a bender like this is great for on car bending.
https://www.eastwood.com/ew-brake-forming-tool.html
Old Apr 16, 2018 | 7:08 AM
  #18
Having a lift will be a great help in replacing the brake lines.
Good luck.
Old Apr 21, 2018 | 6:55 AM
  #19
mmb617's Avatar
I got the job done and the NiCopp lines were nice to work with. Easy to bend by hand without kinking even when the bends were pretty tight.
I'm glad I didn't go with the prebent lines as I can't imagine how you could snake them into place without raising the body off the frame a couple inches.
