Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX How to Install Heated Seats
seat heater is possessed!!
Welcome to the forum...
From the description below, it looks like the only way to access the retaining screws is from the back side, requiring door panel removal...
I would suggest getting a few extra panel retainers from your local auto parts store to have on hand should you damage any beyond reuse... also Harbor Fright has plastic panel removal tools that can really make the process go easier....
Do it right and do it once...
Yup. Bad switch. Changed it out yesterday and all is good now. Of course I did break one of the mounting sleeves. I didn't realize one of the switch's screw mounts had been built into the door handle molding. We'll see how it holds up. It appears to be mounted tight though.
I've never been that good with DIY projects.
Did anyone finally find the solution to the drivers heated seat going berserk? What about disconnecting the switch on the door panel? Mine works normally when the door is open and engine running. Could the wiring be shorted between the door and body?
I replaced the driver's side door module (the problem was on the driver's side), that didn't work. I then replaced the Memory Seat Module under the driver's seat (this part was the most expensive at >$400), but that didn't fix the problem. Last, I replaced the passenger side door module and amazingly, that fixed it. This was years ago and it has worked fine ever since.
Seat heater wiring diagrams attached...I think.
Hope this helps, good luck.
