Serious Vehicle Problem
Old Oct 2, 2007 | 7:13 PM
WIll4Au's Avatar
Default Serious Vehicle Problem
Im new here and have been looking for a forum like this for a long time and glad ive found one. I have a 97 4wd 4door tahoe and have been cursed for about a year now, it started when i would be going interstate speeds mainly up hills and the vehicle would shake violently when it would shift up and you could smell a burning metal smell, i took it to get a diagnostics test and was told a missfire, it started doing it more and more often until the past couple months it is every time i travel at those speeds, i took it to AAMCO Transmissions and was told it was my brakes engaging causing that smell and the shake, i "repaired" it for $300, did not fix, my shop back home did a complete tune-up and i "repaired" it for $400, chevrolet told me a new transmission, got that replaced for $2800, still doing it, and i got it back yesterday, I WOULD PAY somebody to give me a clue as to what the problem might be or if you have ever had a similar problem, it starts to shake in the undercarriage and you can smell a burning metal or wire smell,i have to slow down to about 50 to get it to stop, thanx for any help sorry it is so long
Old Oct 2, 2007 | 9:25 PM
SNO's Avatar
SNO
Default RE: Serious Vehicle Problem
Has the driveshaft (straightness) and U-joints been checked?
Old Oct 3, 2007 | 10:34 AM
MalibuMaxxSS's Avatar
sounds liek a bent d/shaft kinda to me... a u joint would have failed by now if it wsa seized I wuold think, but if your d/shaft is bent it would put strain on the u joints making them heat up and burn the grease inside as well as the needles.....
Old Oct 3, 2007 | 11:01 AM
ZX1100F1's Avatar
The first thing that you need to do is isolate what area the shake is coming from.
Disconnect the front propeller shaft and see if the vibration still occurs.
I also would remove the inspection cover from the rear differential and see if everything looks right inside and there is no debris, I have seen bad rear ends do this and overheat causing a burning odor from overheated fluid.
There is also a chance that the torque converter is damaged, many times when a transmission is replaced the torque converter is not.
doveface
Jun 30, 2015 6:28 PM
seo155
Feb 23, 2010 2:34 PM
98Silverado621
Jul 11, 2009 9:02 PM
Alan4370
Apr 25, 2008 5:05 AM
