Setting Default Homepage
Moderators,
Is it possible to configure my homepage to default to the Tahoe/Suburban forum? When I log in it would be more efficient to go directly to this area.
Inquiring minds want to know
JW
JW
I guess the bookmark would work. Doing what you ask, will take you to the Sub-Forum each time you open your Browser. If that's ok with you, then...
Get on the page you want,
Copy the Web Address at the top of your screen,
Click on the Tools Tab in the menu bar just below the web address you just copied.
Then click on Internet Options, and the General page should open,
Tap the delete or escape button to remove the existing address (should be highlighted in blue probably),
Put your cursor in that box, and paste the new address there.
Be sure to save/apply before leaving the setup box.
(above instructions are for Internet Explorer vers)
Should be able to do it just like you set up your current homepage. On Firefox, just go to Options, Options, General tab and paste the URL of the page you want to be your Homepage.
