She want Start Sometimes ??
Old Mar 4, 2015 | 7:35 PM
Chevy_Girl_Lol's Avatar
Default She want Start Sometimes ??
Hello all,
Every once in awhile, my 2008 Suburban refuses to start. I turn the key and nothing happens.
To get it to start, I have to get a battery jump. Then it starts right up.
I had the battery and alternator tested at two Autozones and battery and alternator tested good.
I don't know if I have a short somewhere or what to do.
Thanks all for any help or recommendations.
Old Mar 4, 2015 | 8:36 PM
Check both battery connections on both ends.
Old Mar 4, 2015 | 9:15 PM
Thank you 73shark,
I will check battery connections on battery and wherever the other ends goes. Will this stop the car from starting sometimes?
Old Mar 4, 2015 | 9:53 PM
Any other recommendations please?
Old Mar 5, 2015 | 8:49 AM
AZSCTACO's Avatar
What shark said.....bad ground may cause problems. If the battery is an AC Delco....replace it immediately. Its a POS.
Old Mar 5, 2015 | 3:28 PM
intheburbs's Avatar
Check your battery connections, maybe hit the metal contacts with a wire brush. Make sure the grounding strap is tight on the block and firewall.
But if that's your original battery, I say replace it.
Old Mar 6, 2015 | 8:50 AM
SabrToothSqrl's Avatar
Default battery
Even if the battery tests OK, can you tried another?
May be worth a shot.
Chevy_Girl_Lol
Feb 20, 2015 8:36 AM
02suburban
Jan 19, 2015 12:33 PM
Chevygirl2445
Jul 16, 2014 12:38 PM
erod7426
Sep 2, 2013 10:20 AM
wildboy74ss
Apr 1, 2009 5:10 PM
