Old May 16, 2007 | 5:52 PM
  #351
TPeezy's Avatar
Default RE: SHOW YOUR HOE! POST THEM PICS BOYS!
Man that looks sick. Youve convinced me to do it. Im starting by painting the bow tie black then ill take the grill to get airbrushed. One more question, did you switch out the headlight bulbs with HID bulbs or did you switch out the entire headlight with an HID setup.
Old May 16, 2007 | 9:22 PM
  #352
07HOE2653V8's Avatar
I went with the 8000K conversion kit from Jpcustoms.com... Although you could probably get them cheaper on Ebay, I trust JP.
http://www.jpcustoms.com/store/custo...at=&page=3
Old May 18, 2007 | 11:20 PM
  #353
M Dot's Avatar
Hello all....New to the forum...I LOVE the Hoe's! I too have a 07, coming out of a 02 'Burban. I see all the Hoe's looking pretty and hooked up, but have a question for all: Has any of your Local Dealerships said anything about voidung the warranty? The reason I asked, is because I have a set of 24's off of the Burban, and the dealer is telling me that if I put them on, that they will have the right to refuse to do warranty work on the truck that will be needed due to the rims on the truck. I have the OEM 20's on there now, but not having the 24's is KILLING me. Any suggestions/comments would be greatly appreciated.
---To be reinstalled on the 07, from the 02...Alpine AI-Net IVA-D310, Orion 2500 HD, 3 JL 12", Polk Interior, and more..Will post pics when done...
Old May 19, 2007 | 1:26 AM
  #354
My salesman told me the same thing, simple work-around though...
-Vehicle requires maintenance = Install factory wheels (Iperform my own oil changes to avoid the
hassle)
Old May 19, 2007 | 1:34 AM
  #355
M Dot's Avatar
Thanks for the response...I've been seeing a few people in my area with after market rims on...and was just curious. The dealer said that they can re-flash the computer to adjust for the transmission shifting and tachometer (up to 22"). Now what about the extra weight that the rims add to the vehicle, the tranny might get burnt out after some time....and the breaks, do they need to be beffed up...just curios, didnt do all that on the 'Burban, and the tahoe is less than a month old...trying to do it right....(has anyone seen dual exhaust yet on the 07's?)
Old May 19, 2007 | 3:24 AM
  #356
More than likely you'll have to upgrade your brakes... The brakes on the Tahoe arerated up to 20 inches (I have 26's), so that's my next big project. Rotora makes a set of 12 piston calipers and power slotted rotors for the '07. Your transmission should be fine... It's made to tow around 7000lb extra pounds, I'm sure an extra 220lbs (or so) won't bother it too much. As for the exhaust, there are tons of options... Just depends on what you fancy. I have flowmaster super 40's with custom pipework.... Corsa andMagnaflow both make bolt on kits
Old May 25, 2007 | 3:12 PM
  #357
whiteogre's Avatar
how do i post pics? when i go to upload nothing shows up
Old May 25, 2007 | 4:14 PM
  #358
p26963's Avatar
Has anyone done the second row console or can suggest one to get? I have second row buckets in ebony. I'm looking for more storage space to say the least.
ORIGINAL: 73shark
[sm=welcomesign.gif]to the forum and thank you for your service. [sm=americanasmiley.gif]
Here's what I've done/plan to do: billet grill, removed rear emblems & GM on sides, rear flaps, moved wheel weights to inside,Lloyd mats, second row console, Superchips, catback exhaust, black bowties, and maybe GM CAI.
Old May 26, 2007 | 12:04 PM
  #359
Here's a pic of one I got from JC Whitney:
[IMG]local://upfiles/1622/E769A5D69BF44F6DAA1BDDE029F5F5BC.jpg[/IMG]
[IMG]local://upfiles/1622/D331012A7CDE43BDACBA8B582196B0B2.jpg[/IMG]
Old May 26, 2007 | 1:20 PM
  #360
dirtywork's Avatar
Check out these rides. There are nice ideas we can use for our hoes... http://www.uniqueautosport.com/ugallery.html
