Side mirror turn indicator
Old Apr 4, 2011 | 11:42 PM
jkj860's Avatar
Default Side mirror turn indicator
I noticed this morning that the passenger side low beam headlight was out on my wifes '07 suburban. Tonight I picked up a set to replace both at the same time. What a chore that was, but thanks to this forum I was able to do it myself. Anyway, driving home after getting the bulbs I noticed that the right side mirror turn indicator was not working either, but I thought maybe thats because the headlight was out on that side. After replacing the bulbs, the mirror indicator on the right side still does not work but the left side does, although all of the turn signals work fine. Any ideas where to look?
Old Apr 5, 2011 | 11:06 AM
15 Year Member
Was it working before you changed out the bulbs? If so, I'd check the connections around where you were working.
Old Apr 5, 2011 | 12:05 PM
jkj860's Avatar
No, it had quit working before I changed them. They seem to have went out at the same time. Maybe just a coincidence though.
Old Apr 14, 2011 | 7:05 PM
jkj860's Avatar
Update: The turn indicator on the mirror starting working again all by itself. I guess it just went on vacation for a bit.
Old Nov 8, 2011 | 7:11 AM
chazmo's Avatar
can you replace factory elec. mirrors on 2011 NBS silverado with indicator turn signals from same year are they plug and play
Old Nov 8, 2011 | 11:47 AM
15 Year Member
Welcome to the forum.
Maybe but connectors might not be compatible and probably have to at least get them programmed by the dealer.
Old Nov 8, 2011 | 11:55 AM
15 Year Member
Sounds like a potential connector problem.
These kind of problems rarely fix themselves.
Old Nov 8, 2011 | 10:20 PM
jkj860's Avatar
I have fixed the problem! It was very simple actually. I sold the money pit and bought a 2012 Hyundai Sonata.
Old Nov 8, 2011 | 11:55 PM
15 Year Member
Sounds like a fun vehicle.
Old Feb 8, 2013 | 4:38 PM
chazmo's Avatar
what is involved in changing dl8 mirrors to dl3 mirrors and hooking them up to function correctly is it plug and play or more involved
