Smog test failed
Old Feb 13, 2013 | 10:54 AM
i82much's Avatar
Default Smog test failed
I was turned down on a smog test due to an air leak in the fuel system. I dropped the tank and replaced the filler hose, vent hose and the short piece of hose that goes to the canister and it failed again. The hose that goes to the canister both from the card and the short piece that goes to the tank look relatively new,
Any ideas where to look next?
Also now on the fuel gauge, before when the tank was full the needle read at say 1:30, now with just a couple of gallons in it the needle is buried reading 3:00 or more
Any ideas?
Thanks
Old Feb 13, 2013 | 1:53 PM
kevinkpk's Avatar
You say canister, is this an older vehicle?
Old Feb 13, 2013 | 2:32 PM
i82much's Avatar
It's a 1990 with the 5.7 TBI
Old Feb 13, 2013 | 3:01 PM
kevinkpk's Avatar
I can't relate to anything newer than a 1970 canister/emission. With that, I believe the fuel tank vent maybe tied to it. The emissions is it raw hydrocarbons? If so, could be the canister needs replaced.
Old Feb 13, 2013 | 3:31 PM
in referring to the air leak...do you mean it has an evap leak? If so post the actual dtc.
Old Feb 13, 2013 | 4:56 PM
i82much's Avatar
All I know is they hook up a suction line to a modified gas cap and check for leaks.
Results were "test Failed"
Sorry can't be more help
Old Feb 13, 2013 | 7:07 PM
kevinkpk's Avatar
That sounds like checking for air leaks or ppm O2, not familiar with this type of emissions. I'd look at the evap canister hose routing, does one say vent or back to tank?
Old Feb 13, 2013 | 8:06 PM
the states test method sounds retarded. The system has an evap monitor that tests itself. There is no need to perform the test they did unless the evap monitor is setting a trouble code. Your states emission testing seems flawed.
if a trouble code is set; that is where diagnostics must begin. Without knowing the states test procedure no one can even begin to understand what they are doing.
get the evap system checked for codes. if a leak is present it will set a code. smoke testing the system will locate the leak.
finally...is the vent solenoid valve closing...a common problem for these trucks
Old Feb 13, 2013 | 8:12 PM
kevinkpk's Avatar
He may be in Europe or Australia?
Old Feb 13, 2013 | 8:15 PM
do fuel guages read in numbers over there? To me 3:00 is time for a sandwich not a quanity of fuel. lol
