Spark plug gap
Old Jan 14, 2016 | 5:55 PM
dave110's Avatar
Default Spark plug gap
What is the correct plug gap? I put Denso platinums in. Manual says .06 and I've read .04, and .045. The Denso's came gapped at .04 and I opened them up to .06 which is a lot to open. The ground is not parallel to the electrode because I had to stretch them so far. It seems my fuel mileage went down after doing this. Should I have left them at .04? Is .06 only for a Delco plug? I'm confused!
Old Jan 14, 2016 | 10:21 PM
Recommend sticking with AC/Delco plugs. Ethanol-free gas helps also.
Old Jan 14, 2016 | 10:39 PM
dave110's Avatar
And what would you recommend gapping them at?
Old Jan 15, 2016 | 1:50 PM
cleveland63b's Avatar
if you do the iridium plugs like gm recommends its .040 and they come gapped if you do platinum its .060
and ALWAYS use oem spark plugs
