speakers not working
Old Oct 1, 2010 | 8:43 AM
ws1313's Avatar
Default speakers not working
I have a 2004 suburban that had its sunroof left open over nght during a rain storm. next moring there was a puddle of water in the middle consoule and on the floors in both the front and back. Front spreakers were working - back were not. now both do not work. Everything else is working. I suspect the water fried the amp. Is the Amp difficult to replace?
Old Oct 3, 2010 | 4:53 PM
RacerX's Avatar
Is the amp under the passengers front seat? Then maybe so. But also if you left the roof open and the have the steering wheel with the volume controls you may have shorted the radio. You ll have to wait till things dry out to see if its reversible. The amp if its the one under the seat is bolted to the floor, like 4 10mm nuts/bolts and maybe one harness. You may have to unbolt the seat to get to all the bolts/nuts.
Old Oct 4, 2010 | 7:57 AM
ws1313's Avatar
thanks for responding:
the amp is under the middle console. got to it over the weekend. there appears to be two plugs into on end of th amp the amp. without removing the amp it appears i could just unplug those two wire connections to a new one to see if that is the problem. Does anyone know where to get a factory amp for a 2004 subruban? dealership quoted me $337.
the rest of the radio and stering wheel controls are all working properly - Thanks
baldana
19
Jan 25, 2018 2:16 PM
damoore2
Sep 10, 2010 7:12 PM
cwpollock
Nov 21, 2009 1:33 PM
mattsternfl
Apr 7, 2009 11:17 AM
Ertsride1
May 9, 2008 1:35 AM
