Speedometer reset
Old Aug 6, 2015 | 12:46 AM
maureenNsgv's Avatar
Default Speedometer reset
how to reset speedometer on a 2001 GM suburban LT after replacing instrument cluster.
Old Aug 6, 2015 | 12:36 PM
Welcome to the forum.
Someone here may be able to answer your question. Might have to go to a dealer tho.
Old Aug 6, 2015 | 2:32 PM
SabrToothSqrl's Avatar
Can you define 'reset'? is it showing the MPH, but it's off, or it doesn't show anything?
Old Aug 6, 2015 | 3:03 PM
IT does not work at all replaced the cluster and speed sensor and still doesn't work>????
Old Aug 6, 2015 | 9:38 PM
assuming you have a new cluster/ it will have to be programmed by the dealer.
here is the great part. if you install it and drive it over a set amount, the cluster with lock out and have to be sent back to unlock it. This will cost you $ so don't let it lock out
sbkmike
Sep 24, 2017 11:03 PM
hl
Jul 10, 2006 12:27 PM
Revredneck
Jun 3, 2006 10:36 AM
