squealing from driver side front wheel 07 suburban 2500
Old Aug 5, 2010 | 6:44 PM
mackda600's Avatar
Default squealing from driver side front wheel 07 suburban 2500
getting a squealing sound when the brake is depressed and then let go (while in motion, i.e. approaching a red light) from the driver-side wheel. any suggestions?
Old Aug 5, 2010 | 8:33 PM
MDTAHOE's Avatar
Professional Mechanic
You need brakes.
Old Aug 5, 2010 | 9:19 PM
mackda600's Avatar
i dont think so, sounds more like a caliper issue?
Old Aug 6, 2010 | 9:23 AM
Hardin Thicke's Avatar
...or a wheel bearing. My Tahoe exhibited the same symptoms last year, and the brakes were fine.
Old Aug 6, 2010 | 10:58 AM
It could be a caliper issue in that it is not retracting quickly after letting off the brake peddle and the pad is dragging.
looking at the pads and how they are worn will give a better indication, retracting the piston and maybe bleeding the system might help if the pads are evenly worn... my .02...
cleaning the caliper slides may also help
Old Aug 6, 2010 | 9:17 PM
The pads have a metal scraper that contacts the rotor when the pad gets worn down to replacement depth. It will initially squeal when you apply the brakes and then as the pad wears down more, it will squeal continually.
Old Aug 9, 2010 | 11:11 AM
Official GM Rep
I would suggest speaking with your local dealership. I have information that, depending on your mileage, you may be covered for some brake components. This of course depends on many different factors like driving habits, trailering and city or highway driving. Hopefully that helps you. If you continue to have issues feel free to contact me.
Jeff Morris, Chevrolet Customer Service
jlpolicky
Feb 17, 2015 2:04 AM
tcr1016
Oct 1, 2014 9:08 PM
Dan Cina
Mar 12, 2013 1:00 PM
