Squeeling 99 Suburban
Old Jun 19, 2009 | 7:36 AM
mnewmanfla's Avatar
Default Squeeling 99 Suburban
My 99 suburban has started to squeel upon start up. It goes away after about 15 minutes. I've replaced the idler pulleys, alternator, belt etc. I'm thinking it's the fan clutch or the a/c but I would like some opinions before I replace either.
What are your thoughts?
Anyone else experience this?
Thanks for any help,
Mike
Old Jun 19, 2009 | 4:34 PM
Mike Sigmond's Avatar
ROTM Coordinator
Is your idler pulley adjustable?
Old Jun 19, 2009 | 9:56 PM
MDTAHOE's Avatar
Professional Mechanic
Did they ask you for the amperage of the alternator when bought the belt? There are 2 belt sizes available. If you have the large of the 2 try the smaller one. Does the noise go away when you spray water on the belt?
Old Jun 20, 2009 | 5:11 AM
mudmaniac's Avatar
Ride of the Month
May 2009
I recently ran into that with a 97 Tahoe, 1 belt is about 1/2 inch longer than the other.
Old Jun 20, 2009 | 7:29 AM
mnewmanfla's Avatar
I don't believe the idler pulley is adjustable.
The noise "does" go away if I spray water on it.
Mudmaniac, so yours was the wrong belt?
Is my belt too short or long?
Thanks for the help on this one.
Old Jun 21, 2009 | 7:13 AM
mudmaniac's Avatar
Ride of the Month
May 2009
From what you have described, the belt you have would be a little to long causing it to be loose.
Old Jun 23, 2009 | 12:14 PM
mnewmanfla's Avatar
Thanks MM I'll go get another belt and see what happens.
33dirt33
Nov 17, 2013 11:52 PM
Got Options?
Dec 17, 2012 6:09 PM
the_vigilante
Oct 15, 2008 3:26 PM
