Steering angle sensor
Old Nov 16, 2015 | 10:35 PM
buttanic's Avatar
Default Steering angle sensor
Anyone have any ABS and Stabiltrac issues related to the steering angle sensor.
Old Nov 17, 2015 | 7:33 AM
knowing nothing about your particular circumstances; generally, this is the situation
there is a tsb about installing a foam wedge at the connector. Usually, the wedge fix does not work; the dtc resets and sensor replacement fixes the problem.
you will have to remove the steering column to replace the sensor.
Old Nov 22, 2015 | 1:04 AM
cleveland63b's Avatar
x2 I've done a lot of them in K models, usually do the tsb pigtail and wedge to be safe
Old Nov 24, 2015 | 10:48 AM
jason78's Avatar
Yes, had all kinds of problems like this on a 2011 Tahoe. Ended up having to get the steering angle sensor replaced under warranty. The dealer said there was a TSB out on it.
