Steering changes after pitman and idler arm replacement
Old October 11th, 2023 | 7:29 PM
Douglas Washington's Avatar
Default Steering changes after pitman and idler arm replacement
I've replaced pitman arm, inner and outer tie rods, and center link. Everything is exact replacement for the truck even compared old with new parts. Got everything on properly and got a wheel alignment. The problem have now is when I turned the wheel full lock left and right the front wheels have a hard time rolling. Like truck has too much steering. The tires are screeching on the ground, like the 4-wheel drive is engaged. I've lifted the truck and only rear wheels are turning. So, transfer case and front diff not the issue. There is no noise coming from steering box or anything. Anyone have the same problem?
Old October 12th, 2023 | 10:27 AM
Cusser's Avatar
Aren't there adjustable "stops" on each side to prevent wheels from turning too much???
drphungky
July 16th, 2023 11:16 AM
sceptre123
September 10th, 2022 8:07 AM
Edward Andriaccio
10
March 6th, 2022 12:57 PM
Arturo
October 6th, 2020 7:19 PM
jcureton
February 5th, 2009 10:45 AM
