Steering changes after pitman and idler arm replacement
Old Oct 11, 2023 | 6:29 PM
Douglas Washington's Avatar
Default Steering changes after pitman and idler arm replacement
I've replaced pitman arm, inner and outer tie rods, and center link. Everything is exact replacement for the truck even compared old with new parts. Got everything on properly and got a wheel alignment. The problem have now is when I turned the wheel full lock left and right the front wheels have a hard time rolling. Like truck has too much steering. The tires are screeching on the ground, like the 4-wheel drive is engaged. I've lifted the truck and only rear wheels are turning. So, transfer case and front diff not the issue. There is no noise coming from steering box or anything. Anyone have the same problem?
Old Oct 12, 2023 | 9:27 AM
Cusser's Avatar
Aren't there adjustable "stops" on each side to prevent wheels from turning too much???
drphungky
Jul 16, 2023 10:16 AM
sceptre123
Sep 10, 2022 7:07 AM
Edward Andriaccio
10
Mar 6, 2022 11:57 AM
Arturo
Oct 6, 2020 6:19 PM
jcureton
Feb 5, 2009 9:45 AM
