suburban 03 air conditioner problem
My chevy air conditioner is not good. The front is warm while the back is cold.. Before 2 months I changed the compressor with cleaning the circulation. Also before 5 months I disconnect the heater hose because it was leaking..
Any idea to track my problem
Have you checked the blend door actuator? Seems to be a common issue with this hvac system. Your symptoms sound just like it has failed.
You can remove the actuator and leave the electrical connected change the temp selector and see if the actuator turns. Also, you can manually open and close the door once the actuator is removed to see if the temp changes coming out of the vents.
Do you think the problem from the evaporator?
adigitaldj1
Uplander
June 19th, 2014 10:15 PM
