Suburban 2007 no crank
I have no crank situation in 2007 5.3 Suburban LTZ. The engine was out for overhaul and after that there is no crank. When ignition is turned on, in the dash it illuminates only the "car and lock" –symbol, but only for few seconds and then it is off. Gauge lights work normally. So there is no check engine light, no tpms, no abs etc light what there are suppose to be. Service Air Bag and Service 4 wheel drive are only problems it states. If I check with my cheap OBD tool it doesnt see any codes. All ground wires are ok. When ignition is on the gas pump doesnt run either. But if t you take the relay out and use wire for shortcut it works. Same thing with cranking, it cranks nicely if you shortcut relay. Relay itself is ok, it doesnt help if you put there brand new relay. What prevents the car from starting?
NotaslookasIdumbIam
2007 - 2013 (GMT900)
August 8th, 2022 5:25 PM
Dcp1234rick@aol.com
Avalanche
October 21st, 2021 8:06 AM
