Suburban 4 Wheel Drive Noise
Old Jun 7, 2021 | 9:18 PM
Jwaus's Avatar
Default Suburban 4 Wheel Drive Noise
I’m trying to diagnose a noise that appears to come from the front drive train. Leaning towards front differential (4WD). it changes tone with gas pedal application. Front cv axles and bearings are new. With 4WD not on why would there be a change in tone in the front differential? Is it still engaged? Could this be rear differential echoing up front seeming to be the front one??? Hoping there is someone here with 4WD experience. Thanks in advance.
Old Jun 9, 2021 | 10:27 AM
repairman54's Avatar
Fluids in diff and t case clean ? Are you testing on dirt or wet road? Dry road will cause noise and issues.
Old Jun 9, 2021 | 12:25 PM
Jwaus's Avatar
Default 4x Noise
The front and back fluid was changed about a thousand miles ago and was sludges. Back more than front. Noise is present same on dirt or paved.
Old Jun 11, 2021 | 8:22 AM
May need to get it up on a lift to run it and listen. U joints can also make noise if dry.
Old Jun 12, 2021 | 8:27 PM
Jwaus's Avatar
Thank you. I will try that.
WF85
Jul 31, 2012 3:45 PM
dh1
Dec 21, 2010 9:03 PM
texasrunner
Feb 10, 2008 6:31 PM
mcculleb
Dec 8, 2007 2:01 PM
Tor Dehli
Feb 24, 2007 9:18 PM
