Suburban rear lift gate lock
Old Jan 24, 2015 | 6:13 PM
Crich's Avatar
Default Suburban rear lift gate lock
2010 suburban lt . The lift gate lock is acting up again!! The lift gate will not unlock with the key fob or the interior lock buttons. The gate locked in the down position but I managed to release it manually with the emergency mechanical release inside.
If the truck sits for an hour of so and you open the drivers door you can hear the rear lock try to open but it won't open all the way.
When you try to open the gate with the exterior handle seems like there is no power at the handle. Seems like the ruck thinks the gate is already open as I'm intermittently getting a message that says the rear lift gate is open .
Already pulled fuse 44 and it's not blown . Left it out for a while hoping it would reset. Nothing ...
This all happened two years ago and went away unexplained until now .
Old Jan 27, 2015 | 4:32 PM
Mini's Avatar
My 2011 LS is in the shop right now for a similar problem. I do not have the power liftgate.
Just received a call from dealer that the touch pad switch is shorted out.
I got a message that the rear liftgate was ajar. It was half unlocked....but ajar. I closed it and it never opened again. I needed an oil change so I took it in to have it diagnosed. They have the switch in stock and it is going to cost just under $300 to repair.
Seems excessive and premature for the switch to fail with 54k miles. I bought it used 12 months and 3 weeks ago....of course GM Certified Warranty is good for 12 months.....
Old Jan 28, 2015 | 11:50 AM
Crich's Avatar
Sounds like yours is doing the same as mine . Funny thing is, mine started doing this two years ago but it only lasted for about a week. Went away and now it's back again ?
Old Jan 29, 2015 | 4:56 AM
Mini's Avatar
They ended up covering the switch. It cost $22. Labor was $210.
If you can get the liftgate open and tye inside panel off it shouldnt be too hard to do.
Old Jan 29, 2015 | 8:13 PM
Crich's Avatar
I've been able to get the lift gate open using the emergency release from inside. Before ordering the new switch I'd like to know how to verify its the switch not the $130 controller. Any ideas ?
dolljason.p
Jul 25, 2020 8:36 PM
RJK
Aug 2, 2019 5:50 PM
TomS209
Jul 23, 2015 12:22 PM
FRANE
Sep 12, 2008 12:30 PM
ABp Anderson
Mar 24, 2008 12:39 PM
