Suburban Washer Fluid Reservoir Question
Old May 9, 2024 | 11:05 PM
3Js's Avatar
3Js
Default Suburban Washer Fluid Reservoir Question
I have a spare single pump windshield washer reservoir from a Chevy extra cab pick up. 2006.
My 2006 Suburban,with rear wipers, reservoir has dual pumps and leaks empty after a day.
There shouldn't be an issue just using the single pump reservoir and leaving the second pump plug just hanging. I never use the rear squirters or wiper.
Am I correct in my thinking?
Old May 9, 2024 | 11:13 PM
🤷‍♂️ try it.
If the reservoir fits, and the pump connector is the same then maybe.
Old May 10, 2024 | 3:21 PM
jfmorris's Avatar
I've got the same issue with my 2006 Silverado 1500. It leaks out all the washer fluid in about a day. However, I recently discovered this. I recently filled it, but did not activate the pump, and it held the reservoir full for a full week. I then activated it to clean the windshield, and it was empty within a day.
My speculation in my case is that the reservoir itself does not have a leak, which is what I was thinking, but that the pump or the line just past the pump has a leak. When the pump/line are dry, nothing leaks. Once you activate it and fill the line, siphon action causes it to gradually empty the entire reservoir.
It is really unfortunate how they buried that reservoir in there where it is extremely hard to get to without removing other things.
Old May 10, 2024 | 10:42 PM
3Js's Avatar
3Js
Well, son of a B.
Removed the tank. Leak testing the resevoir and it looks like it might not be the tank. That's what I get for just presuming without getting underneath and doing a detailed inspection. Probably just a leaking line
toddhegstrom@gmail.com
Dec 8, 2022 1:24 PM
Julz44
Feb 20, 2016 9:33 PM
ladyhawkjj
May 8, 2014 10:47 PM
papawali
Jan 3, 2013 6:16 AM
mrsmoos
Jul 8, 2008 4:18 PM
