suspension question
Old Jun 4, 2013 | 10:33 PM
trainwreck91's Avatar
Default suspension question
on the 2007 suburban ltz-how many air compressors are there?
also is it air ride in the rear only? or both front and rear?
Old Jun 5, 2013 | 12:30 AM
AFAIK there's one compressor in the rear on the driver side and its only is connected to the rear shocks.
Old Jun 5, 2013 | 9:00 AM
thanks, what's AFAIK? is there anything special about the front shocks/struts? i noticed that either front or rear are pretty expensive for shocks
Old Jun 5, 2013 | 7:06 PM
AFAIK = As far as I know
Maybe the Arnott rep can chime in re: front shocks.
Old Jun 6, 2013 | 3:04 PM
ArnottInc's Avatar
Former Sponsor
Default Arnott Front Air Suspension for GM SUVs with Autoride
Designed by Delphi and now manufactured by BWI in Mexico, Autoride comes standard on the GMC Yukon Denali and Yukon XL Denali. The product is also standard on the Cadillac Escalade, Escalade EXT and Escalade ESV where it is known as Road Sensing Suspension. GM also offers Autoride as an option for the Chevrolet Suburban, Tahoe and Avalanche 1500 and as an option for the GMC Yukon XL 1500.
Autoride is a fully automatic ride control system that continually adjusts the damping level on each of the four individual shock absorbers to provide superior ride quality and handling performance. Autoride's "tow/haul" mode helps improve vehicle body control while towing and hauling by offering increased levels of damping. Also included with Autoride is automatic rear level control, an air suspension system that helps keep the vehicle level over a wide range of passenger and loading conditions while also maintaining rear ride travel.
For the 2007 Suburban (with AutoRide) Arnott makes a set of front replacement shocks using new Bilstein shocks. They come with sensor plug in modules so you won't get dashboard warning lights.
New Bilstein / Arnott Front Shock Replacement Kit (Pair)
Part SK-2487 retails for $429.00.
Forum members can use code use code GMForums0313 to save up to 10%* off the retail prices onArnott products for your GM vehicle. You can place your order online at the Arnott Web Store or bycalling Arnott Customer Support at 1-800-251-8993 X 804 Mon – Friday from 8:00AM to 7:00 PM ET. Orders placed by 2:30 ET are typically shipped out the sameday.
*Max savings $75 per order, not valid with any other order or on shipping,taxes or core deposits (if any).
Old Jun 6, 2013 | 8:51 PM
thanks for chiming in. do these replacements have the damping capabilities? or do they perform as normal/conventional shocks?
Old Jun 7, 2013 | 3:55 PM
ArnottInc's Avatar
Former Sponsor
They do have damping capabilities but that comes from the Bilstein shocks not from the Autoride.
Simon-Pierre Lacasse
Mar 8, 2014 7:18 PM
akabavah
Avalanche
Oct 10, 2009 9:54 PM
TxAgs
Apr 3, 2008 10:18 PM
mitranom
Mar 3, 2008 10:18 AM
cheyenne06
Jul 16, 2007 10:52 AM
