Tahoe 2007 22's or 24's
Old May 18th, 2008, 1:58 AM
Cubanborn87's Avatar
Default Tahoe 2007 22's or 24's
I am trying to make up my mind about if i should put 24's or 22's on my 07 tahoe. i heard some people say that if they put 24's the rub really bad is this true and should i just put 22's pr if i put 295 35 24 size of tires on 24's should it be fine?[/align]
Old May 19th, 2008, 9:42 PM
Aquarius14's Avatar
Default RE: Tahoe 2007 22's or 24's
I would go with the 22's (actually I did) if you're trying to keep the same ride feeling. 24's if it doesn't matter & you're going for looks but your ride will suffer. I can even feel a small difference with the 22's. Also once you lower it it will look good which ever you choose. 1 more thing, if you plan on towing anything that has a lil weight or carry a full load a lot you might want to go with the 22's. Hope this helps.
Old May 20th, 2008, 1:18 AM
BMoTahoe's Avatar
Stay away from the 24's. Where they may look good on your Hoe, the rub factor is there and so is the damage factor. You have less rubber between the rim and the road, so you ride will suffer. Hit a pothole and your wallet will suffer. I have 22's on my 07 and had them on my 2000 and they were/are doing just fine and I really don't feel any difference in the ride than when the factory 17's were on it.
Old May 20th, 2008, 1:23 PM
thanks so much for the info guys it did help me
Old May 20th, 2008, 3:52 PM
Aquarius14's Avatar
Another thing, get some info on the best offset. Even though I love my rims they stick out just a lil too much so I have to go through puddles very slowly when turning to keep from slinging water down the side of the truck. I'll try & find out what the offset is on mine.
Old May 20th, 2008, 6:30 PM
fastcarz2's Avatar
24's dont ride as bad as everybody says but a little more tread couldn't hurt
Old May 20th, 2008, 10:11 PM
mary900's Avatar
This site has quite a bit of useful information. Check out the wheel offset calculator.
[align=left]http://www.carbibles.com/tyre_bible_pg2.html[/align]
Old May 20th, 2008, 10:24 PM
e
e's Avatar
20/22/24 or 17" WHEELSfor that matter make no difference whether the tires is going to rub. It has to with the tires overall diameter and width.
Wheel offset will play a factor into this as well. But, like everyone has stated the more rubber, the better the ride. I have 24's and have not second guessed my decision......
Old May 21st, 2008, 4:22 AM
oniscus's Avatar
i run 285/40/24 +30 and theres no rub. as far as the ride is concern, there is a difference from stock 17's but nothing major, just be careful on big pot holes. i work in philly and i'm used to it by now. good luck on whatever choice u make.
24 cons:
a lot more expensive tire
ride
gas mileage went down a little bit for me
no more tpmssensor, it doesnt fit
Old May 21st, 2008, 1:43 PM
what is the difference between 295/35-24 and 285/40/24 tires
Quick Reply: Tahoe 2007 22's or 24's
