Tahoe 2010 universal remote programming
Old Feb 13, 2010 | 10:02 PM
crodriguez's Avatar
Default Tahoe 2010 universal remote programming
Does anyone know how to program the Tahoe 2010 Universal Remote with a Chamberlin LiftMaster garage opener?
Old Feb 14, 2010 | 11:36 AM
TMW597's Avatar
http://www.learcar2u.com/program/
File Type: pdf
Old Feb 15, 2010 | 4:55 AM
10Hoe's Avatar
OMG!! im having the same problem !! I tried everything cant get it to read or learn the remote..
Old Feb 15, 2010 | 11:36 AM
TMW597's Avatar
Just read what I posted and you'll be fine. It only takes 10 seconds if you have a rolling code garage door opener. Just hit the "learn" button on the garage door opener and then follow the instructions for the button you want it to be on your vehicle. MAKE SURE TO WATCH THE LIGHTS ON YOUR HOMELINK. It usually finds the code and the light starts blinking in a matter of seconds. Then it's done.
Old Feb 15, 2010 | 12:43 PM
ltzboy's Avatar
The easiest trick to learn your cars to a rolling code is:
Hit the learn button on the back of the opener.
Within the 20-30 seconds it stays in learn mode hold the remote next to the button you want it to learn and hold for at least 5 seconds.....the garage door light will blink showing it learned the remote again.
Then hit the learn button on the opener again and within 20-30 seconds just hit the homelink button that you programed with the remote. The opener light will blink again showing the homelink button has now been learned.
Your all done.
Old Feb 16, 2010 | 3:21 AM
10Hoe's Avatar
Default Finnaly got it
I took my garage opener cover off turns out it was full of bugs and oil anyways the gunk was trapped behind the red button preventing it from being pushed in all the way. Cleaned it and it worked perfectly thanks guys. If anyone else is having problems with the light not turning on when u press the button check for bugs!!
Old Feb 16, 2010 | 7:44 AM
SabrToothSqrl's Avatar
Default yea
or like me.. .drive your self nuts thinking why doesn't it work... then realize the builder put in some lame *** Wayne Dalton thing that requires a $40 adapter for it to work, and a $30 pin pad vs the $15 sears ones... thanks builder... if I could find you... I would smack you.
joshhighley
Sep 23, 2010 11:46 AM
mk686
Mar 6, 2010 6:57 PM
chachas
HHR
Oct 31, 2009 1:37 PM
dclarkson1
Feb 23, 2007 4:09 AM
sdfd504
Oct 27, 2006 11:19 PM
