Tahoe 4WD help quick!!!!
Old Jul 30, 2013 | 9:53 AM
964door's Avatar
Exclamation Tahoe 4WD help quick!!!!
Hey y'all, im looking at buying a 1996 tahoe 4 door, 5.7 v8 from an individual. He said the tranny was rebuilt with a heavy duty torque converter, its lifted, properly geared and what not. BUT he said the 4WD and I quote "Needs new power inverter switch on front chunk replaced in order for 4WD to work." What does this mean?! Please help guys! thanks!
Old Jul 30, 2013 | 12:59 PM
SWHouston's Avatar
I've never herd of the terms "inverter" or "chunk" as related to a Transfer Case.
What Case do you have ?
Manual or Auto/Push Button control ?
Have you tried conventional operation ?
Old Jul 30, 2013 | 1:08 PM
blueinterceptor's Avatar
Does he mean the actuator? If he does its an electronic part that I understand is a simple enough replacement and kind of common as the connections become corroded.
Old Jul 31, 2013 | 11:32 AM
SWHouston's Avatar
Yea, I'm thinking that's what the guy (seller) meant. Not that he knew much about 4WD, unless he was just trying to snow 964door.
There's actually two functions/actuators.
One which engages the front wheels, and..
one that shifts it into Low Range.
To shift into 4WD-Hi, only one has to work,
To shift into 4WD-Lo, both have to work.
IOW: you must shift into 4WD before you can shift into Lo Range.
964door, have you tried to just put it in 4WD-Hi ?
D Chevy
Sep 17, 2012 12:06 PM
04Greg
Mar 2, 2011 9:46 AM
vpbho
Nov 1, 2010 10:08 AM
waller2003
Oct 19, 2009 9:49 PM
DianaT
Nov 29, 2007 12:12 AM
