Tahoe and AfterMarket gps unit? (new harness from axxess that will work with onstar?)
Old May 15, 2012 | 12:04 AM
bosanci28's Avatar
Default Tahoe and AfterMarket gps unit? (new harness from axxess that will work with onstar?)
today i got some email with an ebook that i find out that axxess come out with some harness that ,see this info:
Axxess GMOS-100
Wiring Harness for Replacing the OEM Radio in GM Vehicles with Non-Amplified or Amplified System and Retain OnStar
Product Features:
Harness for Adding Aftermarket Radios in GM Vehicles with Class II, GMLAN 11, or GMLAN 29 bit System
Retains convenience features that are lost when OEM radio is removed
Designed to retain OnStar and warning chimes
Compatible with amplified or non-amplified systems
Retains factory satellite radio or iPod: Axxess XIA-LCD required and sold separately
Retains factory steering wheel controls and Bluetooth if equipped
Provides 12V, 10A accessory output for aftermarket radios
Mute, Parking Brake, VSS or Speed Sense, and a Reverse output provided for navigation installs
USB Updatable software
Adjustable gain control
One of 3 vehicle specific harnesses are required and included (listed below)
Authorized Internet Dealer
1-year Manufacturer's warranty
Axxess Class II-100 Compatibility:
2003-2006 Tahoe
Axxess GMLAN29-100 Compatibility:
2007-2010 Tahoe
info from here
ebook link here
now,
i was looking at this gps unit here,my brother has it in his dodge ram and is really okay,he paid about 350 while back,now the price come down some,
i was curios if the unit and the harness from axxess will work,for my
2007 tahoe with bose sound ,and i have onstar ,xm and sirius.
i dont really care about the xm/sirius and even onstar.
so is it possible to make the install with the above gps unit and that harnes from axxess?
thanks,for any advice!
some update after researching little more,
i find out here,that
Axxess - GMOS-LAN-012
does:
Description
GM LAN29 Data OnStar, Satellite, Chime Retention Interface
The GMOS-LAN-012 is designed to retain OnStar , OEM Satellite, and to retain the warning chimes that are normally lost when the OEM radio is removed. Provides a 12 volt accessory output for aftermarket radio operation. The GMOS-LAN-012 also provides a Mute, Parking Brake, VSS or Speed Sense, and a Reverse output to make installing an aftermarket navigation radio simple and less time consuming.
what you think?
Old Jun 11, 2012 | 9:15 PM
SamEnnabi's Avatar
pac also makes the harness that give a little better sound quality as the axxess one doesn't sound that great..
Old Jul 9, 2013 | 1:46 PM
klb's Avatar
klb
I can't get sound from my aftermarket radio.
Old Jul 9, 2013 | 2:30 PM
klb Welcome to the forum
Lets start with some basics...
Is this a newly installed unit?
Did it work before you replaced it?
Have you check and double checked all fuses?
Do you get any sound even speaker pop when turning it on?
Is there an aftermarket amp installed or just head unit to speakers?
Are the installed speakers rated for the head unit.. 2ohm, 4ohm 8ohm etc...
What was replaced, radio only, speakers and radio and wiring...
darkhorse
Feb 2, 2015 11:30 PM
TyPierce
Aug 8, 2011 5:21 PM
Tahoetarga
Feb 2, 2008 5:46 PM
TPeezy
Apr 4, 2007 6:41 PM
kirkf
Jan 19, 2007 6:22 PM
