Tahoe making loud grinding noise
Old Mar 3, 2020 | 7:27 AM
Leah Holerud's Avatar
Default Tahoe making loud grinding noise
My 05 tahoe is making loud noise. When I put it in reverese and still have my foot on the brake it grinds hard. It sounds like its coming from the drivers side front. I changed front differential fluid and transfer case fluid. I did the wheel hub assembly on the passenger side a few months ago. I dont remember it sounding the same. Brake pads look good. Tie rodes are close to needing replacing. Somebody I lnow said it could be the flywheel. But that doesnt sound right to me. I just need to get my truck going. Please help
Old Mar 5, 2020 | 6:19 AM
Cusser's Avatar
Did you pull the wheels to check both sides of the brake rotors? Front and rear?
If you can't find and fix the issue, take it to a local independent ASE shop, not the dealer.
Old Mar 9, 2020 | 3:33 PM
yes I checked brakes and rotors they are all good. I was avle to find the area sound is coming from. It seems to be coming from around the transfer case. I cant afford to take it to shop. Since my truck has been down I havent been able to work.
Snake17
Feb 14, 2025 9:02 PM
chris13
Sep 19, 2019 11:20 AM
2014CruzeLT
Cruze
Oct 26, 2017 8:14 AM
OmarJaved
May 15, 2016 9:44 AM
