Temperature Display Very Wrong
I'm rather perplexed... I just hooked up the VSS wire for my nav (check the other thread) and suddenly the thermometer on the rear-view mirror is showing the temperature to be about 25 degrees colder than it should be.
Is there an easy way to recalibrate or reset this thing?? It appears that the compass is working OK, but that's about it.
I'm hoping that the VSS wire thing isn't the inadvertant cause for the thermometer problem.
Any help would be appreciated.
try turning the power off on the rear view mirror for a few minutes and them turn it back on. that should reset the temp and direction. as far as the vss wire goes, where did u grab the vss wire and what color is it?
ORIGINAL: jlenkows
Did you (or anyone really) know that the 2nd gree wire with a white stripe is for the mirror temperature display. And... if you connect it to the radio's VSS pin, it really screws with the temperature...
Yes. I am the consumate IDIOT!!!!!!!!
[sm=oopssign.gif]
[sm=oopssign.gif]
ORIGINAL: jlenkows
[sm=oopssign.gif]
[sm=oopssign.gif]
![Wink](https://chevroletforum.com/forum/images/smilies/wink.gif)
I could barely see when I was working on mine & finally whipped out a magnifying glass to be sure..... However, since your radio generated a VSS error it had to be picking up something other than the expected VSS pulse - probably either a constant voltage or ground. Think of it this way - if the VSS is a pulsed signal - (probably a sine wave) no signal would equal no motion & the NAV unit would see this as a normal non-motion condition. Your NAV would then only update based upon GPS position refresh.
Actually I had the programming done last week - I was impatient to say the least.
I double/triple/quadruple checked that wire that I first tapped. It is definately green with a white stripe.
It is what it is.
It is what it is.
i had a similar problem when i first instlled my navigation...i tried many different wires and none of them would pick up a pulse from the vss wire so it was only tracking through satellite via the gps antenna. finally i just went and got my vss at the wheel and it work great. if u want to know the wire color let me know and i'll check it out for u.
ORIGINAL: jlenkows
It is what it is.
It is what it is.
earnestsierra
February 3rd, 2012 12:31 PM
sureshot313
January 13th, 2010 12:52 PM
chevrolet, chevy, compass, display, displaying, mirror, showing, shows, suburan, suburban, tahoe, temp, temperature, temprature, thermometer, works, wrong
