Temperature Sensor in Headliner - Noise
Old Oct 24, 2013 | 6:35 AM
joeincharlotte's Avatar
Default Temperature Sensor in Headliner - Noise
The last few mornings I have noticed interference coming from the climate control temperature sensor located in the headliner above the driver seat. Strangest thing. It goes away after a few minutes, but it quite annoying at first. I'm hoping this doesn't escalate into a larger problem.
I've searched the forums and couldn't find anything. Has anyone else had this problem? My first guess is to check the grounds, but I have no idea where to start looking. Any help is appreciated!
Old Oct 25, 2013 | 9:52 AM
There is a small fan behind the little grill that goes bad.
Old Oct 25, 2013 | 2:26 PM
Joe In NY's Avatar
I blew both of mine out. Turns out, they were full of dust. The noise has gone away... Just a quick blast with air compressor
Old Oct 25, 2013 | 7:20 PM
I would agree that it probably just needs to be cleaned, don't use too high of an air pressure though as you could damage it...
Here is the procedure for removing it if you so choose to...
Inside Air Temperature Sensor Aspirator Assembly
Old Oct 27, 2013 | 6:22 AM
Thanks guys. This is why I come to this forum. I will take a look today.
Old Oct 27, 2013 | 7:46 AM
I wish I could get a hold of newer electronic service manuals....my data starts falling out at the 2009-10 models
I have found new model paper manuals but they are way to hard to search, scan, copy paste
SEAN
Sonic (Aveo)
Oct 9, 2010 6:44 PM
ousig2408
Feb 19, 2010 4:29 PM
Tahoeguy2
Aug 19, 2008 10:42 AM
mgunim7631
Jun 5, 2007 12:49 PM
mazdacaddi
Feb 16, 2007 5:03 PM
