Temperature Setting for Vehicle in HVAC Auxiliary.
Old Apr 2, 2016 | 3:39 AM
Punit Yatnal's Avatar
Default Temperature Setting for Vehicle in HVAC Auxiliary.
Hi All,
I designed the Board HVAC Auxiliary board which has 3 sensors.
1. Lowe Duct Air temp Sensor -Auxiliary(part number -> 12160947)
2. upper Duct Air temp Sensor -Auxiliary(part number -> 12160947)
3. Inside Air temp Sensor -Auxiliary (part number->22834330)
So in addition to this we have mode actuator and Air temp actuator and blower motor.
so if mode actuator in face mode , i am taking measure temp from avg of upper and inside air temp sensor.
so if mode actuator in Leg mode , i am taking measure temp from avg of Lower and inside air temp sensor.
so if mode actuator in face/Leg and auto mode , i am taking measure temp from avg of upper ,lower and inside air temp sensor.
So is the all three condition true?.
If so , i need to know the pid logic to maintain set temperature. Could you please help me in getting these.
I also want to know what the PID logic for Blower speed in auto mode?.
Right now i am varying the speed of blower based on inside air temp sensor and set temperature.
also can you guys shared the register table of all 3 sensors. Since i am missing some temp calculation also.
Regards
Punith
Old Apr 5, 2016 | 1:23 AM
Could you please any one reply to me?
I need to know the resistor table for this part number
Amazon.com: ACDelco 22834330 GM Original Equipment Cabin Air Temperature Sensor Aspirator: Automotive Amazon.com: ACDelco 22834330 GM Original Equipment Cabin Air Temperature Sensor Aspirator: Automotive
