Timing
Old Feb 6, 2014 | 1:54 PM
truthbtold's Avatar
Default Timing
Greetings
I own a 99' gmc suburban, 5.7 vortec. 150K. I had the unfortunate experience of learning how cheap the factory intake manifold gaskets are. When it broke, coolant ran out faster than I could put it in. So, changed out the gasket. what a job.
I carefully marked the distributor for reinstallation and when I tried to start it, it cranked but no start. Thinking I did something wrong to the timing, I reset it and double checked the marking etc. As it turned out I also learned how cheap the spider injectors are as well. So I read up on it and upgraded the injectors as well. Turned over and started right up like new. Not throwing any codes, and runs fine.
My question is: Should I still have it scanned to get the timing spot on?
Old Feb 6, 2014 | 1:58 PM
SWHouston's Avatar
I'd wait an see...
Check your Fuel mileage, if lower than normal, then yes, get it set.
Old Feb 6, 2014 | 7:24 PM
RichC10's Avatar
You could try the trial and error method. Just move the dist a couple of degrees at a time. If it seems to run right you must have it pretty close. I think you have 2 deg. either side of perfect before it sets the check engine light.
jmms
HHR
Apr 17, 2015 4:22 AM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
mog703
Jul 26, 2006 2:34 PM
attmchappo
Jul 26, 2006 2:27 AM
sdelano
Oct 3, 2005 9:49 PM
