Tire pressure
Old Jan 3, 2007 | 11:37 PM
hatchet's Avatar
Default Tire pressure
One last question...
Can anyone recommend a good tire pressure gauge? I have an older digital el cheapo from the Shack. But, it is at least one digit less than what the DIC registers. I have the 20" inch rims and larger tires which are rated at 32PSI. The DIC registers 33PSI all around even after I let a little air out to register 31PSI on my handheld gauge. I know the sensors have to relearn position after a tire change and to be honest, I don't know if the dealership reset that after my last rotation a few weeks back. I know I didn't reset it but will to see if that makes a difference. I wasn't even sure if that had anything to do with the tire pressure sensor anyway.
At any rate, I'd like to find a good handheld gauge, digital or not, as a backup to the DIC. I recognize the value of proper tire pressure and have gotten many miles out of my tires by taking just a few extra minutes to insure proper inflation. Makes sense to me!
Thanks!!
Old Jan 4, 2007 | 1:52 AM
engine2's Avatar
Default RE: Tire pressure
I have a digital guage and it matches the DIC readings exactly. The brand on the side says "Accutire". It was a gift I received several years ago. I believe it came from Brookstone. If not google it. Good Luck
Old Jan 4, 2007 | 2:25 PM
biglg's Avatar
I think mine is accutire also, got it from Sam's a couple years back. I think it was $20 or something. It always matches my Tahoes pressure reading as well.
Old Jan 5, 2007 | 10:01 PM
I rec'd a digital from Restoration Hardware (looks just like the Accutire). It matches within 0.5 psi of the DIC reading.
Old Jan 6, 2007 | 11:11 PM
hatchet's Avatar
Check!
That's the one I will find. Thanks for the info!
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
lauraherota
Oct 19, 2011 9:04 AM
bamafutbal
Jul 29, 2010 9:24 PM
