Tire Pressure Monitor Sensor Help!
Old Mar 8, 2007 | 3:10 AM
ambiguous216's Avatar
Default Tire Pressure Monitor Sensor Help!
I have taken my 07 Tahoe to be serviced for the tire pressure sensor going off intermintently and it still not fixed. I has been taken to service 4 times and all four times the guy says he reset the TPMS. I even took it to two different dealers. What will it take for it to go away?
Old Mar 8, 2007 | 4:03 AM
ockevin's Avatar
Default RE: Tire Pressure Monitor Sensor Help!
You may have a bad receiver.....There is a recall on certain VIN's that need the replacement receiever for TPS and remote entry.
I had the same thing and now they ordered me a new one under warranty.
Old Mar 8, 2007 | 3:25 PM
rbarrios's Avatar
like he said-
when i read your post- 1st thing that came to mind was the receiver.
theres been some issues with Impalas remote keyless entry, remote engine start, and the tire pressure monitor. the current fix is to replace some parts....
Old Mar 8, 2007 | 4:52 PM
ZX1100F1's Avatar
In this case a faulty receiver is most likely not the root cause of the problem but it may cure the display errors due to the reprogramming that is necessary after the RCDLR is replaced.
Instead of insisting on a replacement receiver I would have the dealer reprogram the RCDLR with the latest software update available through TIS2WEB and then reset the low tire pressure threshold to the door jamb placard spec's with Tech2 and relearn the TPMS sensors with the gun and that should solve the problem.
Old Mar 8, 2007 | 11:40 PM
maries 07 tahoe's Avatar
ZX IS ON TOP OF ALL THE ISSSUES,, GET YOUR EYES ON ALL HIS HELP IS THE MAIN MAN IN FOR INFORMATION.. I HAD TO GET MY TIRE DEAL FIXED AND I MADE A COPE OF WHAT HE SAID TO DO AND HANDED IT TO THE SERVICE TECH PERSONALLY.. FIX .......... thanks so much zx MARIE
Old Mar 10, 2007 | 10:28 PM
bobbyt's Avatar
I bought 22 inch rims with TPS and my light is still on how do i fix this?
Old Mar 11, 2007 | 12:25 AM
DarkOne's Avatar
Go thru the manual and try to relearn the positions....if that doesn't work the receiver may be bad.. I took mine in for the alarm and when the put in the new reciever(so they say) the TPS stayed on. They finally figured it out by replacing the reciever again and it works fine now.
racingrusthotrods
Colorado
23
Dec 25, 2013 6:13 PM
Red Ron
Jan 8, 2009 7:21 PM
bama1
Dec 7, 2008 10:09 PM
FARRNARK
Oct 23, 2008 9:12 AM
fe_pony
Mar 22, 2008 7:33 PM
