Torque Specs 2012 Caliper Bolts
I'm searching for torque specs and I'm finding some different numbers online, so I'd like to share what I think are the most reliable and hopefully someone can correct me if these are wrong.
I have a 2012 Suburban 1500, 4x4
Guide Pin Bolts / Brake Caliper Bolts
Front: 74 ft lbs
Rear: 28 ft lbs
Caliper Bracket Mounting Bolts:
Front: 148 ft lbs
Rear: 122 ft lbs
T30 on the Front Rotors: 106 inch lbs
Lug Nuts 140 ft lbs
Please correct me if any of these numbers seem wrong. Thank you!
Front: 74 ft lbs
Rear: 28 ft lbs
Front: 148 ft lbs
Rear: 122 ft lbs
Lug Nuts 140 ft lbs
oilcanhenry (June 30th, 2023)
Front: 74 ft lbs
Rear: 28 ft lbs
Front: 148 ft lbs
Rear: 122 ft lbs
Lug Nuts 140 ft lbs
Front: 74 ft lbs
Rear: 28 ft lbs
Front: 148 ft lbs
Rear: 122 ft lbs
Lug Nuts 140 ft lbs
keep cranking on the bolt until it suddenly becomes loose, and then back it off a quarter turn.
j/k ... don't do that.
