Tow / Haul button does not work .. 2001 Suburban
Old May 19, 2017 | 9:04 AM
StarChyldd's Avatar
Default Tow / Haul button does not work .. 2001 Suburban
This is my 2nd post .. I'm burning it up!
Question .. I had my transmission rebuilt a couple of years ago and when I picked it up from the shop, after a few days, I noticed the tow/haul button on the shifter didn't work. I called the shop and the guy was sort of a douche about the whole thing so I didn't want to deal with this guy any longer, plus I had nothing to two or haul any longer since I sold my trailer. .. Cut to today, I am trying to fix the little things to get it back up to snuff .. Does anyone know why this might not be working? Do I have to take it back to a shop? Maybe some wires or a switch or fuse was left not reconnected, or some oddball thing like that.
Any help or opinions on what I should do, not on the douche shop owner? Thanks!
Thx!
Jason
Old May 19, 2017 | 9:16 AM
it has nothing to do with the trans work. shop owners are tired of hearing...ever since my insert part name was worked on, my insert unrelated part name is broken.
If the button is built into the shift lever; remove the steering column trim. the wiring that runs from the column shifter commonly breaks. inspect the wiring. the fix is to repair the wiring or get new parts...which is a new shifter assembly.
Old May 19, 2017 | 9:51 AM
StarChyldd's Avatar
Thank you for your help.
Why do you think then it happened just after the trans was rebuilt? Would the shop have had to do anything with the tow/haul function? Or maybe it is just a coincidence?
I will check this weekend .. Thanks!!!!
Jason
Old May 19, 2017 | 7:38 PM
the trans and the tow haul switch are not related. they wouldn't go near the switch to replace the trans.
The switch is an input to the tcm/pcm. the tcm/pcm sees the input and then makes shift schedule programming changes.
its a 16 year old truck. you are already twice over its life expectancy. old stuff breaks
Old May 21, 2017 | 10:29 AM
StarChyldd's Avatar
Yea, and things are going out here and there. Thanks for the info!
