tracking problems
Old Dec 13, 2006 | 2:14 PM
uktahoe's Avatar
Default tracking problems
I am having problems with my 98 Tahoe. Its a 2 door 4x4 Z71. I,ve had the tracking checked and its OK, but I'm still experiencing a pull to the left.
Tyres are ok, one had worn unevenly prior to tracking check and alteretion, and has now been put on the other side, which has made no difference.
Has anybody any experience of this problem and any idea what to look at next?
The GM certified dealer I have to rely on here in the UK seems to be out of ideas except check everything, which is going to cost!
Old Dec 13, 2006 | 5:23 PM
bk94si's Avatar
Default RE: tracking problems
Sometimes bad tyres can cause that also. I had mismatched on one of my cars and it did that. Try putting the rear tyres up on the front and see what happens.
Old Dec 13, 2006 | 6:04 PM
doo600's Avatar
Put the front end up on jacks and try and wiggle the wheel by hand back and forth. If it moves you may have issues with steering box, tie rods, tie rod sleeves, ball joints, or wheel bearings. Get a pro to look at it, this is nothing to mess around with.
I assume you checked the tire pressures right?
Old Dec 20, 2006 | 8:10 AM
uktahoe's Avatar
Thanks for your suggestions bk94si and doo600.
Iam going to swap the tyres over front to back as soon as I can, see if that helps.
I'll check the wiggling suggestion as soon as possible to. Tyre pressures are OK although I do have a slow puncture I have to keep topping up.
firelance911
Oct 21, 2010 2:49 PM
herve
Jul 28, 2008 12:11 PM
