Tranny or transfer case problem
![Cool](https://chevroletforum.com/forum/images/icons/icon6.gif)
I have a 02 suburban 4x4. I just replaced the rear end. Replaced fluids and filter in motor, tranny, and transfer case. I was driving it for a few days and noticed the transmission was slipping. I checked fluid which was low and added to the full mark. A week later, at the stop sign I take off and it sounded like it popped out of gear. I let the rpms come down and it made a loud grinding noise and went back into gear. A few days later, same thing happened and only a mile down the road it seemed to grind down into 2nd gear from Drive.
Is this a transmission problem or could this be a transfer case problem?
Sounds like it was trying to go into 4x4-lo by it's self. You probably have a NP-8 Case, and the reduction you mentioned (Drive to 2nd gear) is comparable to the 2.7 ratio.
Did you notice any of the Dash Indicators showing it was trying to change ?
Possibly if you were to transfer into 4Lo and back a few times, it may correct it's self.
Thanks for the info, I didn't notice any indicator lights on when it happened. I'll keep an eye out next time. I did, however, put the truck on jack stands and lifted the rear tires off the ground. All gears except for 2nd turn at idle. I had to gas a little in 2nd gear to get the tires turning.
Though your problem is a bit different than most Case shifting problems, most times lack of use allows the Fluid to get goopy. Many times a Fluid change and as I said before, shifting back and forth (in/out) 4WD-lo often gets things working again.
Lakepres
September 8th, 2014 10:30 AM
1991jimmy4x4
July 8th, 2011 12:45 AM
mattwehrwein
June 7th, 2009 10:44 PM
chevythunder25
March 18th, 2009 6:33 PM
