Trans Temp/Gauge Question
Old Feb 10, 2008 | 6:36 PM
june82000's Avatar
Default Trans Temp/Gauge Question
I recently purchased a new cluster for my '03 Suburban 1500 (4WD) and installed it today. I upgraded from stock to include the trans temp guage, which I din't have before. I noticed that it didn't appear to move at all after the install and was wondering a couple of things. Supposedly the vehicle is pre-wired and it should basically be plug-and-play is what I was told. So it it true that my vehicle should already have the temp sender? Also, I only drove it about 5 miles, but shifting through all the gears, I figured the guage shoud at least move a little bit.
Anyway, just looking for some input.
Thanks Guys.
Old Feb 10, 2008 | 8:46 PM
guvner's Avatar
Default RE: Trans Temp/Gauge Question
I'm guessing you were impatient? How cold is it where you are?
Old Feb 11, 2008 | 7:38 AM
june82000's Avatar
ORIGINAL: guvner
That's what I'm hoping, It's my wife's vehicle so I'll have her keep an eye on it. Hopefully it'll start moving. I hear that anything under 200 degrees while not towing is acceptable. It was in the low to mid-50s and extremely windy yesterday.
Thanks.
Old Feb 11, 2008 | 2:32 PM
ZX1100F1's Avatar
The 2003 1500 series GMT800 products are not pre-wired for a transmission temperature gauge only the 2500 and 3500 series products are and in their case the gauge is standard.
Old Feb 12, 2008 | 8:15 AM
june82000's Avatar
ORIGINAL: ZX1100F1
Hmmmm, When you say 'not prewired' are you saying the wiring and the sensor areNOT installed - or that it just doesn't have a sensor,but the wiring is there for it?
Thanks,
Old Feb 12, 2008 | 11:50 AM
ZX1100F1's Avatar
There is no wire to transmit trans temp info to the cluster although there is a temp sensor inplace.
If your transmission runs too hot you will get a message on the DIC display.
Old Feb 12, 2008 | 1:36 PM
june82000's Avatar
ORIGINAL: ZX1100F1
Hmm, I was unaware thatthe DICwould display an overtemp tranmission - interesting. So what I gather is that there is a sensor, it's just not feeding a signal to the guage because there is no wire in place to do so. I guess (?) I would be able to run one myself, have you ever investigated that?
Dave
Old Feb 12, 2008 | 2:59 PM
ZX1100F1's Avatar
Not that simple, the trans temp info is relayed to the cluster via the Class-2 Serial Data system.
Old Feb 13, 2008 | 7:26 AM
june82000's Avatar
ORIGINAL: ZX1100F1
Well, I guess I got lucky. My wife finally drove it yesterday (she's been sick for a few days) and it works!!
Fishinfooleric10@aol.com
Feb 20, 2013 9:04 AM
enacer
Mar 18, 2010 7:13 AM
Mauler
Mar 2, 2009 6:40 PM
mcculleb
Feb 22, 2008 6:16 PM
june82000
Feb 10, 2008 7:47 PM
