transfer case problem
When I put my Tahoe in reverse and give it gas it locks up and makes a grinding noise it sounds like it's coming from my transfer case... anyone know what could cause this?
It sounds like you're not making a total shift into 4WD. Check adjustment of operating mechanism, or, disconnect from below, and try to shift it manually from under your ride. When up on a chassis rack, you can rotate the wheels to make it easier and see if it actually is engaged.
marine_man
September 16th, 2011 11:05 AM
tlaura21
May 30th, 2011 6:09 PM
chevythunder25
March 18th, 2009 6:33 PM
