transfer case problem
It sounds like you're not making a total shift into 4WD. Check adjustment of operating mechanism, or, disconnect from below, and try to shift it manually from under your ride. When up on a chassis rack, you can rotate the wheels to make it easier and see if it actually is engaged.
tlaura21
May 30, 2011 6:09 PM
chevythunder25
Mar 18, 2009 6:33 PM
