Transmission blues 4L 60
Old Apr 20, 2026 | 3:31 PM
SenorPescador's Avatar
Red face Transmission blues 4L 60
ok, I hope someone can answer this I have pan off 3rd time
more success with a pump to drain the fluid off, as far as making a mess....
it does not go into 3-4 gear from 2nd stays stuck was gradual, then bam,
I replaced all 5 solenoids , reset CPU is good and putting out the signal to the solenoid
but am thinking it is a broken spring in that on actuator so
question is, I am on the ground{72 y.o., but still surfing, jaaa} it is still bolted to bell housing
so if I bolt loose the valve body what is going to fall out of the top part? I am thinking the 7-8 little *****? so I can put on bench to check the actuators and springs , but maybe it is just the upshift3-4 and see if the spring is shot??
you help me I will make sure you have a GOOD times in El Salvador where I moved to in 1994, built a nightclub in 96...... and hope to drive this 05 suburban back, in May or June..
or it just might be trip to pick and pull, arrrrgh
senorpescado.com and tropicooltours.com
the motor has 240K but still sounds like a sewing machine, occasional lifter click but not that bad
Old Apr 20, 2026 | 3:51 PM
Rednucleus's Avatar
I'll bet it needs a rebuild, sorry; hope you prove me wrong
SenorPescador
Apr 5, 2026 11:47 AM
BlownFuse
2007 - 2013 (GMT900)
Sep 6, 2024 10:14 PM
reagan102
Mar 2, 2022 11:19 PM
dkg57
1988 - 1998 (GMT400)
May 26, 2016 5:07 AM
Erikb
Feb 26, 2011 8:18 AM
