Transmission fuel temp
Old Jun 27, 2019 | 1:03 PM
Nest's Avatar
Default Transmission fuel temp
I have a Chevy suburban 2013 LT and what is the Normal temperature for transmission fuel? My car reach up to 205F
help please , thanks!!!
Old Jun 27, 2019 | 1:54 PM
Irish_alley's Avatar
I'm here for the party
just driving it? on my crew it stays around 180 or so. even when towing i dont like to see the temp much higher than 215
Old Jun 27, 2019 | 1:58 PM
KChevy75's Avatar
It's slightly hot. The manual says normal operating temperature is 71°C to 93°C (160°F to 200°F).
How's the trans fluid fill? Start the Suburban and let it reach normal operating temperature then check the transmission fill while it's running, in park and on a level surface. If it's low, add some fluid.
How many miles since the last trans flush and filter change? Could just be in need to a flush and filter change. Is the fluid dark? Does it smell burnt?
My 2007 has a different trans but it sits at about 165 °F when it's 100 °F outside.. I added a transmission cooler a few years ago so mine runs a bit cooler than one without. The manual for my model year shows 180°F to 200°F.
