Trouble Codes, Check Engine Light
Old Dec 12, 2011 | 1:48 PM
chazwel's Avatar
Question Trouble Codes, Check Engine Light
How do you get the trouble codes when the truck doesn't run? With the key? TIA
Old Dec 12, 2011 | 5:31 PM
EinST's Avatar
Buy or rent a scan tool or code reader and then plug it into the OBD data link port under the dash with key on?
Old Dec 12, 2011 | 6:06 PM
Dirtiest Hoe I know's Avatar
^ agree, or borrow a friends.
Throw a battery charger on the battery if the car is weak, which I imagine it is if it doesn't run / no return power from alternator.
Old Dec 13, 2011 | 6:28 AM
chazwel's Avatar
On some makes you can turn the key and get codes with blinking lights, maybe not this make. I killed and charged the battery once. Thanks Guys.
Old Dec 13, 2011 | 11:14 AM
EinST's Avatar
That was OBD I days, i.e., 1995 or older. Anyway, the CEL should be lit with key on, engine off. If yours won't start, the CEL is not really a good diagnostic aid.
Old Jan 24, 2012 | 12:18 PM
chazwel's Avatar
Bought a $20 scanning tool, will let you know the results.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
chuck49
Jun 29, 2010 11:30 PM
Retiredphoneman
Apr 29, 2009 12:05 PM
u149360
Dec 9, 2008 5:56 PM
