tune up cost
Old Jun 28, 2018 | 9:13 PM
sandra irvin's Avatar
Newly Registered
Default tune up cost
2009 shev. suburban 130000 miles tune up what will dealer do? and avarge cost?
Old Jun 29, 2018 | 4:20 AM
oilcanhenry's Avatar
Replace spark plugs; change fuel filter, change air-filter, check for codes. Unless its not operating properly, that's a modern "tune-up".
Back in the dark old ages, that might mean also rebuilding the carburetor, installing new points and condenser and checking that the ignition
timing was correct and that the vacuum and centrifugal timing advance was operating as it should. The ECM controls all that stuff nowadays
and carburetors are not longer used, since fuel injection became the norm in the mid-late 1980's,
Speaking of fuel injectors, if you are running cheap gas, you might want to clean them up with some Chevron Techron or Seafoam down the gas tank.
And it's Chevy, not shev.
Old Jun 29, 2018 | 9:14 PM
Sandra: welcome to the forum.
Since the fuel filter is part of the fuel pump, you won't need to worry about replacing it unless the fuel pump goes bad.
Old Jun 29, 2018 | 11:02 PM
check your owner manual maintenance schedule
at that mileage
the trans fluid, 4wd fluids , coolant should have been changed
cost for changing spark plugs is probably $250
Old Jul 4, 2018 | 7:17 PM
at that mileage
Am I reading this correctly? $250 to change 4 to 8 spark plugs?? Sure glad I spent all those years learning auto-tech!!
Last time I checked $75-90 bucks an hour labor was norm at most shops. Did all 8 plugs on my K-1500 in about an hour.
Old Jul 4, 2018 | 9:26 PM
the cost of 8 iridium plugs in Canada are $100-$130. Labour rates at a dealership in the city average $130-140hr. Add 13%tax.
$75 hour door rate is for mom and dad shops in the small towns 10 years ago....at least in Canada. Techs in Canada make 30% of the door rate.
